AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Problem with AMDETAIL AC Mechanical 2015
2 REPLIES 2
panaview
574 Views, 2 Replies
Hello!
I have problem with AMDETAIL. I can use Rectangle or Object to choose area for detail. When I use circle, area for detail is not there where should be. It is much higher. I can't choose area what I want. It is much higher. I don't know why...
Any ideas?
2 REPLIES 2
acwtzwegers
in reply to: panaview
Your picture looks as if you are darwing on a different plane then the XY plane. AutoCAD Mechanical will put everything on XY. Switch on your UCS (should show XY) or viewcube (should show top) to see what is "up".
(besides that the detail view functionality is so bugged our company had to leave it behind (a few years back already). It is more secure to use scale areas and add an AM_4 frame with text manually.)
panaview
in reply to: acwtzwegers
Hi!
You have right! There was some problem with plane! Thanks for your help
”Boost
