AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Problem using AMDEFLINE command
2 REPLIES 2
jbogaard
555 Views, 2 Replies
When we use the AMDEFLINE command in AM 2013, no dialog box appears after selecting start and endpoint.
Does anyone of you have the same problem?
Thanks, John
Tags (2)
2 REPLIES 2
michaelsu
in reply to: jbogaard
Hello John,
I could not see the issue at my side. Can you try again after you reset settings to default from start menu?
Thanks.
Michael Su
SQA Engineer
Please mark any response as "Accept as Solution" if it answers your question.
jbogaard
in reply to: michaelsu
Hi Michael,
Thanks for your reply.
What seemed to be the problem is that we entered a network location in the 'AltGeniusPath' setting. When we clear this setting, everything seems to be working fine. We're now testing if clearing this setting does not produce other problems.
Regards, John
”Boost
