When we use the AMDEFLINE command in AM 2013, no dialog box appears after selecting start and endpoint.
Does anyone of you have the same problem?
Thanks, John
Solved by jbogaard. Go to Solution.
Hello John,
I could not see the issue at my side. Can you try again after you reset settings to default from start menu?
Hi Michael,
Thanks for your reply.
What seemed to be the problem is that we entered a network location in the 'AltGeniusPath' setting. When we clear this setting, everything seems to be working fine. We're now testing if clearing this setting does not produce other problems.
Regards, John
