Hi
I am using the following code to convert dwg to pdf using DWG true view dll.
public AcCtrl m_dwgdll;
m_dwgdll = new AcCtrl();
string m_Path = "d:\architectural_example-imperial.dwg";
m_dwgdll.PutSourcePath(m_Path);
string[] str = new string[2];
str[0] = m_dwgdll.GetSourcePath();
m_dwgdll.SilentPublish(str);
//m_dwgdll.SetPc3File("DWG2PC3.PC3");
I have set the Location(string value - d:\\output.pdf) in HKEY_CURRENT_USER\Software\Autodesk\DWG TrueView\R7\dwgviewr-E001:409\Profiles\<<Unnamed Profile>>\Dialogs\AcPublishDlg\ in the registry
but still i did not save in d:\ drive also i did not any error from above code.
KIndly help me to save the PDF file from DWG file using DWG true view.
Looking forward your reply.
Regards
Guna
