AutoCAD Mechanical General Discussion
tdigiannurio
Message 11 of 13 (117 Views)
Re: PROBLEM 3D CONNEXION CONTROLLER BUT INTERFERES WITH AUTOCAD MECHANICAL
10-19-2011 04:29 AM in reply to: tdigiannurio
if the problem i srelated to touching 3D connexion controller in Autocad 2011 or 2012 try typing the command 'PLAN" and then the command "world" and that should strighten out the drawing. I have never had a situation where the ndrawing was unusable.
tdigiannurio
Message 12 of 13 (117 Views)
10-19-2011 04:30 AM in reply to: VinodBalasubramanian
I have upodate one installed and the problem ihas NOT been  addressed
tdigiannurio
Message 13 of 13 (117 Views)
10-19-2011 04:35 AM in reply to: VinodBalasubramanian
This issue has been reported by me through my subscription to Autodesk support. I have been only told there they are aware of the problem and they are working on it. But my concern is there enough emphasis on this problem by others. I assume that the "squeeky wheel gets the most oil" principle applies here.
