AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Print is viewable in TrueView but error when I try Autocad
2 REPLIES 2
732 Views, 2 Replies
I am trying to open a .dxf file using AutoCad Mech 2011. I can view the .dxf file in TrueView but I get an error when I try to open the same .dxf file in AutoCad Mech. 2011.
Any ideas?
2 REPLIES 2
inchul.lee
Hi dinokio85,
Welcome to AutoCAD Mechanical Discussion Group!
What is the message you're seeing? It would be good if you can attach the drawing that you're having a problem opening.
In the meantime, please do the followings:
Thanks.
Inchul Lee
pendean
Could it be the DXF file is a format higher than your Mech 2011?
Like DWG files, you cannot open a 2013 or higher in 2011.
”Boost
