Since I'm using Autodesk Mechanical Desktop, I want to start using its function, but with this power dimension its pretty annoying!
I move my dimensions using grips and move commands and it looks good and everything..close the drawing. But when I open it goes back to the original position and what I need to do from there is match property it so it goes back to the MOVED position. Very annoying... and its causing a big deal in the office. Any fix or suggestions?
Maybe I shouldn't use Power Dimensions anymore...
