AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Polylines not filled...
6 REPLIES 6
KF090
1408 Views, 6 Replies
Polylines are being filled in but according to FILLMODE they are being filled in for both new and existing drawings.
Although some drawings that I open with PLines are showing them filled in and I can't find the difference between them.
Any ideas?
AutoCAD Mechnical 2012
6 REPLIES 6
Volker_C
in reply to: KF090
Are you still having problems with the Fillmode system variable?  When you state that FIllmode shows that pline objects are shown as filled, are you saying that all your drawings existing and new have the variable set to (1)?
Can you post an example drawing, one with expected behavior and one with unexpected behavior?
Cheers!
Volker
Please let us know if your questions have been answered by selecting, "Accept as Solution"
Volker C.
SR Technical Support Specialist, KDE
Autodesk Customer Council | Only One AutoCAD | AutoCAD Blog
KF090
in reply to: Volker_C
Attached is a DWG of an existing file with the issue.  Yes, FILLMODE is set to (1).
I can't seem to find the new DWG that I had the issue with and I can't recreate the issue as any new DWG I start now does not seem to have this issue.
My guess is that it has to do with specific drawings because other users have this issue with existing drawings too.
Thanks.
Volker_C
in reply to: KF090
Thanks for supplying the drawing file try the following from the command line:
Command: plan
Enter an option [Current ucs/Ucs/World] <Current>: w
Regenerating model.
If this works please mark the solution as solved. Cheers!
Volker
Volker C.
KF090
That worked, thanks.
Is there a known cause that we can try to avoid in the future?
Volker_C
in reply to: KF090
Sorry, I have looked and there is no known issue in regards to a product defect. It could be a start up LISP routine or third party application or user input. Wish I could give you a better answer.
Cheers!
Volker
Volker C.
Accidently pressing the middle mouse button and moving the mouse while the 'Shift' aad 'Alt' keys are held down throws the drawing out of World Space.
”Boost
