i assume you have set your plot device ( network? or local?) / plot setting
(scale, paper size, etc)correctly. After click "ok" button, does printer
print blank or no reaction at all? Any dialog message appear? Is it happen
on ALL companion files or some particular one? Do you check the "Full
Preview" before start plotting?
Chee Wee
QA/ACM
Autodesk, Inc
"38graham97" wrote in message
news:8907935.1094049198995.JavaMail.jive@jiveforum1.autodesk.com...
> It appears that the problem is with the Companion file. Any idea why I
can't print the part?
