I am running Revit MEP 2011 and have just installed Windows 7, and when i insert pipe fittings they display too small. I have a 200mm pipe and if I insert an appropriate pipe fitting it displays too small, but if I do a properties check it tells me the fitting is the correct size. I have been running Revit MEP 2011 with Windows XP and had no problems does anyone have a fix ?
Dear Rikki,
I dont know revit, but the same problem i hv faced with autocad, basic funda is checking the the dimension of how much difference is? Go to options - AM Standards - scale, check the model scale value, shd be 1:1 and also options - user preferences - insertion scale - both source & target unit.
hope it will work.
bye
rb
