Working on Mechanical 2010 Version 3
I added a PDF underlay to my drawing and then scaled it in model space so that all dimension equaled 1:1. I started doing some layout work with it and worked for about an hour......all of a sudden the PDF no longer displayed. The frame still showed, it showed it as loaded everything appears to be fine but it doesn't display anymore. Solutions anyone?
Mark
You can try to open the pdf underlay Properties, and set "Show underlay" to "yes".
hope helps
