I am looking for a way to stop AutoCAD from treating these commands (pan/zoom) as actions such as 'LINE' or 'ERASE.' It would be nice to only undo (or save) changes that actually modified the drawing in some way. Thanks in advance.
-Andrew
Solved by VinodBalasubramanian. Go to Solution.
HI,
You cannot exclude both commands from UNDO function. However you can combine them. Please go to options and select the check box as highlighted below. This might save some of your time.
