AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Ordinate dimensioning
1 REPLY 1
shastu
1257 Views, 1 Reply
I have just installed AutoCAD Mechanical 2014 and am trying to apply ordinate dimensioning. I am use to clicking on the command, selecting the point of origin, and then picking the multiple points I want to dimension and then drag them all out the same distance. How do I do that in this program? I select ordinate dimension and it doesn't ask me where I want my origin point, and I can only pick one point and then have to start the command over. That is not efficient at all. Can someone please tell me there is a better way?
1 REPLY 1
Keshava_Murthy
in reply to: shastu
Before selecting the origin point, you need to select the object, Steps below.
1. AMAUTODIM > Ordinate tab > Make the required settings > OK
2. Select the object > Press Enter
3. Select the first origin of dimension and place the dimension.
4. Continue to pick mulitple points manually on the object for more dimensions.
Please click ACCEPT SOLUTION if my post helps in solving your issue or answering your question.
Keshava Murthy
AutoCAD Mechanical Team
”Boost
