AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
opening splash screen
8 REPLIES 8
Message 1 of 9
1273 Views, 8 Replies
When I start ACAD Mech 2014, I get an empty box pop up in front of my work area, and then
the opening splash screen opens in Internet Explorer. How do I get this to stop?
And I've done the obvious of removing the check mark, but I guess since it's in IE, it's of no use.
Is there a setting somewhere to force this to stop?
Thank you for your help.
8 REPLIES 8
Message 2 of 9
Wow, that is actually pretty cool... how did you manage to get ACM to do that? (Been looking in how to mod the splash screen for ages)
But ok, does this happen in all ways of starting up ACM or just using the desktop icon?
Message 3 of 9
Looks like it doesn't matter how I start the program.
I really don't want the splash screen, and if the check box would work,
I wouldn't have it coming up at all.
Thanks for your response.
Message 4 of 9
dgorsman
Try adding the /nologo argument to the shortcut, in the same way as you would provide a profile name argument.
Message 5 of 9
in reply to: dgorsman
Thank you, but I have no idea what you are telling me.
I'm basically a self taught user that just scratches the surface
of what the program can do.
Message 6 of 9
Shawn_Niles
Can you try a Reset of the program and see ifthat resolves thi? Go to Start > All Programs > Autodesk > *your AutoCAD  product* > Reset Settings to Default. It will then run through a few prompts and reset. Please let us know the results.
Shawn Niles
Message 7 of 9
in reply to: Shawn_Niles
Had my fingers crossed on that, but no, it still starts with the splash window being blank and what should be in the splash screen opening in an IE window.
And what makes it even better, is the zip file that was created that had my settings changes, was empty.
Message 8 of 9
Shawn_Niles
Try the following:  Go to Options > System tab > Help and Welcome Screen section > Uncheck the 'Access online content when available' checkbox. Does it now work?
For additional information and tips, please see the post below:
http://forums.autodesk.com/t5/AutoCAD-2013-2014-DWG-Format/Blank-Welcome-Screen/td-p/3391541
Shawn Niles
Message 9 of 9
Thanks a million. That did the trick.
”Boost
