AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Offline Help downloaded, installed, but not found
5 REPLIES 5
CrAzY-MiKe
4892 Views, 5 Replies
As the subject line suggests, it is installed, yet AMech2013 still tries to go online for help.  We have a proxy server policy that IT refuses to alter to allow access for the online help.  How can I make AMech2013 look locally for help files?
Michael Hollingsworth
CAD Administrator | Flexicon Corporation
Autodesk Product Design and Manufacturing Collection 2021
5 REPLIES 5
michaelsu
in reply to: CrAzY-MiKe
Can you try the following steps?
1. Download offline from the link below.
http://usa.autodesk.com/adsk/servlet/item?id=18769284&siteID=123112
2. Install the help doc after download
3. Launch AutoCAD Mechanical and go to Options dialog->System tab-> uncheck "Access online content when available"
4. And then go to Files tab in Options dialog -> Help and Miscellaneous File Names -> Expand the node to see "Help Location" -> Put the location of your offline help.
For example, the default could be " C:\Program Files\Autodesk\AutoCAD Mechanical 2013 Help\English\Help\index.html"
5. Ok in Options dialog
6. Then try to invoke help again.
Thanks.
Michael Su
SQA Engineer
Please mark any response as "Accept as Solution" if it answers your question.
CrAzY-MiKe
in reply to: michaelsu
Thanks! In classic "Simpsons" style, I'm sitting her going "D'OH!"
aguitton116
I did exaclty this and in the french version it doesn't work on my customer stations (windows 7 pro x64 french).
Here are some attachements, maybe I did something wrong, or something else is blocking the access to the files (they have strong rights restrictions).
aguitton116
in reply to: aguitton116
The last screenshot that I could not attach with the previous post.
kabby
Many thanks & kudos for the solution.
”Boost
