I know this is a common topic, but I have tried some of the previous suggestions and still am stuck. I have lost all "am-" mechanical commands. Options only show limited tabs - like vanilla Autocad. Tried repair and a reinstall - still no mechanical. Am running Mechanical 2013 (product design suite prem) on Windows 7. Was using as supplied acadmpp profile with no changes - Vault add in still works, just no mechanical commands. Do I need to tinker with the registry? Anyone - please help: timing is terrible (working on rush job)!
Solved by Steve_Bessette. Go to Solution.
Please check to see if the AMPP.cuix file is loaded. This can be done by typing CUI for Customizable User Interface. You should see the AMPP.cuix icon in the upper left hand corner.
Also, have you attempted to run the program from the Start menu? (Start - All Programs - Autodesk - AutoCAD Mechanical 2013) If so, what were the results.
