AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
No Mechanical commands - tried reinstall/repair
1 REPLY 1
Winks87
452 Views, 1 Reply
I know this is a common topic, but I have tried some of the previous suggestions and still am stuck.  I have lost all "am-" mechanical commands.  Options only show limited tabs - like vanilla Autocad.  Tried repair and a reinstall - still no mechanical.  Am running Mechanical 2013 (product design suite prem) on Windows 7.  Was using as supplied acadmpp profile with no changes - Vault add in still works, just no mechanical commands.  Do I need to tinker with the registry?  Anyone - please help: timing is terrible (working on rush job)!
James Winkler
1 REPLY 1
Steve_Bessette
in reply to: Winks87
Please check to see if the AMPP.cuix file is loaded.  This can be done by typing CUI for Customizable User Interface.  You should see the AMPP.cuix icon in the upper left hand corner.
Also, have you attempted to run the program from the Start menu?  (Start - All Programs - Autodesk - AutoCAD Mechanical 2013)  If so, what were the results.
Steve Bessette
Support Specialist
Product Support
”Boost
