AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Narrow diameter symbol.
2 REPLIES 2
ukrainian
772 Views, 2 Replies
When using the diameter dimensioning function the diamter symbol displays narrow. This problem I have only in one drawing.  (ACADM 2008)
See attached pictures.
Anyone know solution of the problem?
Thanks.
2 REPLIES 2
michaelsu
in reply to: ukrainian
Can you try to change a different font name or set Width Factor in Text Style dialog? Any luck?
Thanks.
Michael Su
SQA Engineer
Please mark any response as "Accept as Solution" if it answers your question.
ukrainian
in reply to: michaelsu
Hi.
Yes when I change a font to ISOCTEUR or Arial all work correctly. Width Factor in Text Style dialog for all fonts is equal to "1".
With that in the Special Characters dialog boxes diameter symbols are different for txt.shx font.
”Boost
