When using the diameter dimensioning function the diamter symbol displays narrow. This problem I have only in one drawing. (ACADM 2008)
See attached pictures.
Anyone know solution of the problem?
Thanks.
Solved by ukrainian. Go to Solution.
Can you try to change a different font name or set Width Factor in Text Style dialog? Any luck?
Hi.
Yes when I change a font to ISOCTEUR or Arial all work correctly. Width Factor in Text Style dialog for all fonts is equal to "1".
With that in the Special Characters dialog boxes diameter symbols are different for txt.shx font.
