AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Multiple lines using LINE command
5 REPLIES 5
jedenton
465 Views, 5 Replies
When using the line command and typing in a dimension for the line, there will be two lines, one is the correct dimension and there will be a  line on top of the dimensioned line and is just a random length line that is then deleted to leave the correct line. Ran a repair, did not fix issue. Not good on explaining the issue...but basically getting two lines using the line command instead of just one.
5 REPLIES 5
jedenton
in reply to: jedenton
Re-installed Autocad......fixed issue..
Jon.Dean
Glad you fixed your line problem, was a bit drastic; re-installing.
You could have just "Reset Settings to Default" from the Start Menu.
Jon.
Jon Dean
jedenton
in reply to: Jon.Dean
What all does that reseet Jon?
Jon.Dean
It resets AutoCAD to how it was when you first installed the product.
Just a quicker method than having to re-install.
Jon.
Jon Dean
jedenton
Ok, thanks for the tip.
”Boost
