Does anyone know if multiline attributes and amtitle is supported in AutoCAD Mechanical 13?
As far as I know, multiline attributes are not supported in AMTITLE if you use those "GEN-TITLE-XXX{xxx}" tags. But you can define your own multiline attributes and it should work like normal block.
The problem I get is that when I insert the title block using AMTITLE, I do not get the ellipse button to edit the multi-line text. Even if I double click on the title block after inserting it I do not get the ellipse button to edit the text.
However I did find out that if I select the title block and select properties, I do get the ellipse button in properties.
