I recently upgraded to AutoCAD Mechanical 2013 and have my CUI set up. My dimensions do some weird things because of Mechanical Standards. I only really need to use Standard AutoCAD 2013 to perform my work. When I try to use the same CUI as I did in Mechanical I get the following error message.
Now I can't even start standard AutoCAD because the message never goes away. How can I migrate my settings from Mechanical to Standard AutoCAD?
Solved by michaelsu. Go to Solution.
Can you try it after Reset Settings to Default by Start button ->All Programs->Autodesk->AutoCAD Mechanical ?
Also, just wonder whether you have installed 2002 version of AutoCAD. If so, please try it after uninstall it. We have a known issue with 2002 side by side.
I apologize for the extra wording at the end of my reply e-mail. In the future, I will log in to the discussion and post my replies directly.
Now you cannot reset settings for one product only. Through Reset Settings, you have a option Backup and reset custom setting. so you can first backup your custom setting in autocad mechanical and then reset it.
Hope it helps.
