Solved by michaelsu. Go to Solution.
You can use "-toolbar" to turn on toolbar. If you don't know the name of toolbar. You can simply invoke dimension toolbar. then right click on the dimension toolbar and then you will see the list of toolbars. You can simply tick the toolbar you want to see.
Command: -toolbar
Enter toolbar name or [ALL]: dimension
Enter an option [Show/Hide/Left/Right/Top/Bottom/Float] <Show>:
