AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Mechanical/ mechanical classic
2 REPLIES 2
martmcfeely
1197 Views, 2 Replies
When using 'mechanical classic' view, I am able to right click on the space at the right of the banner that opens an Autocad menu, from here I can open various toolbars, ie dimension and text. Is there any way of doing this using the 'mechanical' view?
I'm new to Autocad so please excuse the stupid question if there's a simple way!
2 REPLIES 2
michaelsu
in reply to: martmcfeely
You can use "-toolbar" to turn on toolbar. If you don't know the name of toolbar. You can simply invoke dimension toolbar. then right click on the dimension toolbar and then you will see the list of toolbars. You can simply tick the toolbar you want to see.
Command: -toolbar
Enter toolbar name or [ALL]: dimension
Enter an option [Show/Hide/Left/Right/Top/Bottom/Float] <Show>:
Thanks.
Michael Su
SQA Engineer
Please mark any response as "Accept as Solution" if it answers your question.
martmcfeely
That's great, and very obvious now I come to think!
Thanks a lot for your help!
”Boost
