LMTools v11.9.0.0 Build 87342 x64_n6 - shows correct server name but ffffffff for the ethernet.
I did the ipconfig and pulled the MAC for license file D48564458F9C
Placed the license file on the server, pointed LMTools at it
LICPATH.LIC file on the Client has server name followed by zeros
Obviously a MAC disconnect
The server has teamed nic cards, rumor has it this version of LMTools will not handle this.
Where to do I go from here so I can get autocad Mech out to my users?
Thank you
Dan Westcott
International Automotive Components
Teamed NICs do cause an ffffffffffff problem. However, so long as your .LIC file matches your physical NIC address then your status enquiry should show available licenses. The client will connect via hostname resolution to IPv4.
If your NLM is running properly then you shouldn't have a problem.
For faster responses concerning Autodesk licensing issues, please post your questions in the Installation and Network Licensing user forum here:
http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
Sorry not good a reading between the lines.
Do I just edit the .lic file and put in the mac address given by ipconfig (or enter the fff.. to match the NLM )??
(I did not see the install.. as a choice on the group to post to on the dis grps page - did I miss it)
Thank you
I did the ipconfig and pulled the MAC for license file D48564458F9C - Teamed nic but this is what ipconfig gave me
I used this MAC to get the license file from autodesk and that mac is in the license file
I pointed LMtools at the license file given to me by autodesk but it lists ffffff
Using the deployment that was built I installed the Autodesk on a client PC. The
LICPATH.LIC file on the Client has server name followed by zeros, fffff nor D485644.... is in the client file,
3 places for the mac to show up and 3 different values. Did the IPCONFIG give me a bogus nic or is LMtools messed up since the deployment LICPATH.LIC is wrong
The license display is not correct I did a reread and checked the log this is the result
10:24:50 (lmgrd) Starting vendor daemon at port 2080
10:24:50 (lmgrd) Using vendor daemon port 2080 specified in license file
10:24:50 (lmgrd) Reread: Started adskflex (pid 2372)10:24:50 (lmgrd) Done rereading
10:28:22 (lmgrd) Please correct problem and restart daemons
AMECH_PP_2005_0F
10:24:50 (adskflex) 47400ACAD_E_2005_0F
10:24:50 (adskflex) Wrong hostid on SERVER line for license file:
10:24:50 (adskflex) F:\Apps\Autodesk\NLM\License\AMECH_PP2005usohhur-fp01.lic
10:24:50 (adskflex) SERVER line says 000802ceb062, hostid is d48564458f9c
10:24:50 (adskflex) Invalid hostid on SERVER line
10:24:50 (adskflex) Disabling 2 licenses from feature 46900AMECH_PP_2005_0F(12D4 C08B F4E1 AF68 )
10:24:50 (adskflex) Disabling 1 license from feature 47400ACAD_E_2005_0F(17C2 F58D FEF5 604C )
10:28:07 (adskflex) No valid hostids, exiting
These are the old licenses on the from the old server - It is like LMtools is pointed to the new license file, but the FlexLm service running is still finding (or trying to find) the old license files. How do i get the service and LMtools in sync? Why is it stll looking at the old license files - very confused here - what can I reinstall to fix or what files do I delete ?
Status
Flexible License Manager status on Thu 8/4/2011 14:13
[Detecting lmgrd processes...]
License server status: 27000@USOHHUR-FP01
License file(s) on USOHHUR-FP01: F:\Apps\Autodesk\NLM\License\AMECH_PP2005usohhur-fp01.lic:
USOHHUR-FP01: license server UP v9.2
Vendor daemon status (on usohhur-fp01):
adskflex: UP v9.2
Feature usage info:
Users of 46900AMECH_PP_2005_0F: (Error: 2 licenses, unsupported by licensed server)
Users of 47400ACAD_E_2005_0F: (Error: 1 licenses, unsupported by licensed server)
Yet at the bottom the bottom it says
My last post was chopped
Yet at the bottom of the status inquiry it says using license file F://///amech-pp2012enlicense.lic ?? Why is it stll insisting on the 2005 licenses? When I stopped the server, the status line said - Stopping server - it never came back with stopped successfully, but when I clicked on the start it did come back started successfully.
ding ding ding, we have a winner. Thank you - i was running the new lmtools but pointing to the old lmgrd version. deleted and readded the service and wonder of all wonders, it served up a license.
Your help was greatly appreciated. Have a great day, I know mine just got better!
Do I have to close this thing or something, or does it just wither away?
