I am using Mechanical 2011 with SP2, Win XP SP3.
This problem has just started in the last couple weeks so I wonder if it is some setting that may have gotten changed. Most of the time (but not all the time) when I type the minus character, it opens the title bar menu for window sizing (restore, minimize, maximize, etc.). It doesn't seem to matter if I have the cursor selected in the drawing area or in the command line, it still happens just the same.
This is getting really annoying because when I enter a negative value or type -AR for command line array, it resizes the window instead.
Solved by emily.xu. Go to Solution.
Workaround: set system variable Menubar = 0.
Also, you can find some posts on this topic:
http://forums.autodesk.com/t5/AutoCAD-2011/dash-key-goes-to-menu/td-p/2690027
http://forums.autodesk.com/t5/AutoCAD-MEP/Autocad-MEP-2011-MINUS-KEY-Bug/td-p/2700100
Hope that helps.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
