AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
LOCATION OF LINK TO JPG. FILES
2 REPLIES 2
605 Views, 2 Replies
I would like to upload the attached file to the vault. However there were a couple of jpg.s attached to the sheet that are nolonger available. I have attempted deleting the jpgs from the dwg but still recieve the error message that they are missing when I attempt to upload them. Where do I need to look to find and kill them?
Thank you
2 REPLIES 2
Go To Tools/Pallets/External References
This will open a box showing all external files that are or were attached to the drawing. References the drawing cannot find will have a warning triangle on the icon. you can right click them and select detach, this will remove them completly from the drawing.
You can relink the images using the Fount At field at the bottom section of the pallet if you ever need to do that in the future.
thank you
”Boost
