Hi there,
I'm running Autocad Mechanical 2010. I can't seem to reset my leader note (AMNOTE) scale to a value of "1". It seems that scale has been fixed to 6.5 (refer to the attached pic). Changing the scale from the properties pallette will only rectify the problem for a single instance and it seems to revert back to 6.5 for every new leader that I have created.
Does anyone know of a permanent fix to this issue? I'm sure there's a setting/command for this.
Thanks in advance!
-Wan
Can you please check AMSYMSCALE sysvar and set it to 1?
