AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Leader note/ AMNOTE Issues
1 REPLY 1
wan.mohd.firdaus.w.a
1212 Views, 1 Reply
Hi there,
I'm running Autocad Mechanical 2010. I can't seem to reset my leader note (AMNOTE) scale to a value of "1". It seems that scale has been fixed to 6.5 (refer to the attached pic). Changing the scale from the properties pallette will only rectify the problem for a single instance and it seems to revert back to 6.5 for every new leader that I have created.
Does anyone know of a permanent fix to this issue? I'm sure there's a setting/command for this.
Thanks in advance!
-Wan
Tags (3)
1 REPLY 1
Can you please check AMSYMSCALE sysvar and set it to 1?
Thanks.
Michael Su
SQA Engineer
Please mark any response as "Accept as Solution" if it answers your question.
”Boost
