hello~
i'm korean autocad user.
i have some question about autocad mechanical 2012.
1. copy command is OK~ block layer color is not changed
2.i use copybase command (ctrl+shift+c) when i copy the block.
but block layer color is changed to white when i copy.
anyone know about the this situation??
ateachments *.dwg file and *.jpg file
I tried your dwg and COPYBASE to select the objects and paste it, but I didn't see the color changed. I am using AutoCAD Mechanical 2012 SP2.
What about reset Settings to default from start menu->Autodesk->AutoCAD Mechanical 2012? Can you still reproduce this issue?
hello~
