AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Is this layer bug in autocad mechanical 2012??
2 REPLIES 2
476 Views, 2 Replies
hello~
i'm korean autocad user.
i have some question about autocad mechanical 2012.
1. copy command is OK~ block layer color is not changed
2.i use copybase command (ctrl+shift+c) when i copy the block.
but  block layer color is changed to white when i copy.
anyone know about the this situation??
ateachments *.dwg file and *.jpg file
2 REPLIES 2
michaelsu
I tried your dwg and COPYBASE to select the objects and paste it, but I didn't see the color changed. I am using AutoCAD Mechanical 2012 SP2.
What about reset Settings to default from start menu->Autodesk->AutoCAD Mechanical 2012? Can you still reproduce this issue?
Thanks.
Michael Su
SQA Engineer
Please mark any response as "Accept as Solution" if it answers your question.
in reply to: michaelsu
hello~
I reinstalled Autocad mechanical 2012 and update service pack 1 and 2
ctrl+c and paste ...only " 0" layer is changed the white
my windows system is 64bit
but 32bit system is no problem.
my english is not good
if you send me your e-mail, i'll send you video about this problem
my email is bomige@naver.com
thank you your reply
”Boost
