When I "Zoom All" my drawing becomes so small that I cannot see any detail. I tried resetting the drawing limits. However I am having an error when selecting the limits.
I type "limits" and then it asks me to select the lower left corner. I click somewhere in the drawing and then it asks me to select the top right corner. I click somewhere in the drawing. Then I receive a message that states invalid limits and it asks me to click in the lower left corner. This continues forever until I escape out of the command.
Any other way to force a zoom to the view I want? Since I can't reset the limits it means I can't really rely on zoom all or zoom extents.
An excellent suggestion. That's pretty much what I usually do in this scenario with one exception. I do cutclip and then select all and then just shift+select what I know I want to keep.
Unfortunately when I pasted it into a fresh drawing and zoomed all I still couldn't see what it was.
Still wondering why the limits command didn't work because I've had success with that in the past.
"Still wondering why the limits command didn't work because I've had success with that in the past."
The limits command will not allow you to create limits with objects outside of it. If you have used LIMITS before with success, there must not have been any objects outside of your definition. Or, you might have clipped the objects which would have been outside your definition.
