AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
import/export geolocation
3 REPLIES 3
nstalker
3723 Views, 3 Replies
Is it possible to export geolocation from one drawing to another?  I'd like to be able to copyclip the geolocation and pasteclip it into another drawing.  Both drawings have the factory in the same location relative to the world axis.  I just don't want to have to go through the trouble of orienting the marker again.
3 REPLIES 3
steve216586
in reply to: nstalker
Have you tried PASTEORIG? Or even copy with base, using 0,0,0 as base, then paste at 0,0,0 in second drawing? Once pasted in the second drawing, you could orientate the UCS by object.
"No one can make you feel inferior without your consent. "-Eleanor Roosevelt
nstalker
in reply to: steve216586
thanks for your response!  I'm pretty sure my UCS is set up the same with both drawings and I'm familiar with the procedure to copy/paste geometry and maintain location from one drawing to the other.  My question has to do with geolocation.
Yong.Jing
As AutoCAD Mechanical combined with AutoCAD, it provide the function SetLocation. You could use Insert > Location > Set Location > From Map or From file to insert the geolocation. For more information, you could find it from help: About Setting Geographic Location. http://knowledge.autodesk.com/support/autocad-plant-3d/learn-explore/caas/documentation/PLNT3D/2014/...
Yong Jing
Product Support Senior Specialist
Technical Support, CSS, GPS
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
如果我的回帖解决了您的问题,请点击 "接受为解决方案" 按钮. 这可以帮助其他人更快的找到解决方案!
”Boost
