AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
How to type in feet, inches in command line
14 REPLIES 14
Message 1 of 15
Vet1003
117746 Views, 14 Replies
I have AutoCAD Mechanical 2004, I set this up a while ago and got a new computer. I loaded my CAD in it and now I can't seem to do command lengths using feet, inches. It will only allow inches for lengths. How do I change this back? Can someone help me out?
Ray
14 REPLIES 14
Message 2 of 15
Sridhar-Autodesk
in reply to: Vet1003
Set units to Architectural and then try.
Command: units
Change units type from Decimal to Architectural.
Thaks,
Sridhar
Software QA Engineer
Manufacturing Solutions Division
Sridhar Subramani
Senior Product Owner
Message 3 of 15
Vet1003
I did that but still requires me to place everything in inches. Use to be able to type in( 12',3 ) no parenthesis and it would take the measurement, but now I can't do that. Is there a new format for this input in the command line now?
Message 4 of 15
Sridhar-Autodesk
I am able to enter below vaules at the command line after setting the units to Architectural.
command line: Pick a point or 1',1'
Specify next point: @12'3,0 or @12'3",0 or @12'3",1' or @12'3,1'
Specify next point: switch otrho on and enter 12'3" or 12'3 (3 is considered as 3")
According to the value you enter; 12',3 what does 3 stand for; is it 3" or 3'.
can you provide an example the way you are entering lengths at the command prompt to draw a rectangle?
Sridhar
Sridhar Subramani
Message 5 of 15
Vet1003
This is the command after selecting a line. I tried to make the line 12'3" in some cases. The 3 after the , is usually taken as inches as default. here is an example of the commands:
Command: _line Specify first point:
Specify next point or [Undo]: @12',3
Point or option keyword required.
Specify next point or [Undo]: 12
Command:
Command:
Specify next point or [Undo]: 1'2"
Specify next point or [Undo]: 12',1"
Specify next point or [Undo]: 12',3"
Message 6 of 15
Sridhar-Autodesk
I could enter value @12',3 if the units is set as Architectural. The behavior is same in all the releases from AcadM 2004 through AcadM 2009.
If units is not set to Architectural, then I see error message "Point or option keyword required" as what you see.
Sridhar
Sridhar Subramani
Message 7 of 15
That doesn't work on mine. I think you are configured for a non-USA number.
All I have to type is 12'3" or 12'3.
Jerry
wrote in message
news:5966839@discussion.autodesk.com...
Sridhar
Message 8 of 15
sathish7
Please give input  in systax in command line
( feet-inch)
Example
Line
Pl. spec. point: 6'-5"
Message 9 of 15
steve216586
Go to "UNITS" and change to Arch.  Then change the "units to scale inserted objects" to feet or unitless.  Whatever you want.  Then go to system variable or type "UNITMODE" on command line.  Change that to "1".  You should be able to now specify lengths on your command line in the following format:  (1'-3") or (1'3") - minus the parenthesis.
UNITMODE-Controls the display format for units. By default, the format for displaying measured values differs slightly from the format used for entering them. (You cannot include spaces when entering measured values.)
0 Displays fractional, feet-and-inches, and surveyor's angles in "report" format using spaces as delimiters
1 Displays fractional, feet-and-inches, and surveyor's angles in "input" format without including spaces and, in some cases, substituting dashes for spaces
"No one can make you feel inferior without your consent. "-Eleanor Roosevelt
Message 10 of 15
artenutri
hei, here in my keyboard to mylself type 14'-2'' I type 14 then the key key to insert inches.png then I type - normal, then type 2 then shift and key to insert inches.png
Message 11 of 15
murugesan1003
sir,when I want to draw a line of length 4feet and 6 inches how I should enter the value either 4.5 or 4.6 please justify......
Message 12 of 15
steve216586
in reply to: murugesan1003
Using decimal input, 4.6 is equal to 4.6 inches. If you want 4 feet - 6 inches, you will have to convert all to inches and use 54 as your input.
Message 13 of 15
abhi.leo.m
in reply to: steve216586
type the command
L then press enter key
5'-9" for 5 feet 9 inches
Message 14 of 15
To draw a line 4'-6" you can enter that as
4'6 (quickest)
or
4'-6
or
4'-6"
or
4'6"
For something like 4'-6 3/4"
use
4'6-3/4 at command line
or
4'6.75
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Message 15 of 15
bennerebe
I had this same problem and none of these solutions worked for me.
I then found this command line solution that worked:  DWGUNITS
See image.
I can now enter 21' and my line will stretch to 21 feet.
”Boost
