I'm ballooning a drawing and adding to my parts list using the AMBALLOON command. When I manually add a balloon from within the model environment, a node appears from which I add my leader to finish ballooning the object. In the model environment the node is visible, but if I switch to a layot created for printing, the node is not visible (although balloon and leader is).
Is there a way to make these nodes visible on the sheet contained in the layout/in paperspace mode?
Jim
Hi There!
The following steps will automatically identify the nodes as requested.
1. Select the column object
2. Right-click. Click Add Selected
3. Place your cursor over any of the nodes in the column grid, and, without clicking, press the CTRL key. **A temporary red circle should appear over each node**
4. Click the node
The red circles will show you where the nodes are located. This should resolve your question, but please feel free to reach out with any further questions you might have.
