Do you need help to find the current value or do you need help assigning a value?
Type AMSYMSCALE in command line. The initial value is 1. You can change it to any positive integer from there also. Try an increment which matches your plot scale.
In Autocad Mech AMSYMSCALE scale value for model space. How to set or get model space scale value in Normal Autocad.
In AutoCad Mech they set model space scale value. Check this command AMSYMSCALE in Mech or type option in AM:Standard tab you can find Model Space.
In Normal Autocad 2012 the set CANNONSCALE value is equal to amsymscale value in mech autocad.
Here i attached the sample drawing for your reference
