AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
How to Flip 3d objects?
2 REPLIES 2
2169 Views, 2 Replies
i recently purchased AutoCAD 2004 and i am in the process of learning how to use it. One thing i can not figure out is how to Flip a 3D object. it is on the x plane, but i would like it on the y plane.
Thank you for your time,
2 REPLIES 2
I have exactly the same problem
steve216586
What command are you using to "flip"? Do you mean rotate from the XZ plane to the XY plane using the X axis as the axis or rotation? If that is the case, you will have to go into the 3D Tools tab and use the pull-down and change it to the appropriate axis of rotation.
"No one can make you feel inferior without your consent. "-Eleanor Roosevelt
”Boost
