I am trying to move the hatch by pick the end point of hatch line. But, it is not working without explotion. Is there any command to enable grib or object snap inside hatch. Kindly let me know.
Suresh
Solved by suresh_070379. Go to Solution.
Click on "powersnapoptions" (or type _ampowersnap) and go to filter options - switch on what you want and press Ok.
i tried with ampowersnap=>filter options=>deselect hatch 1 & 2. But, after that also it cannot able to select the end point inside the hatch. Kindly let me know what mistake i did or provide any other solution.
Suresh
Please also set OSNAPHATCH and OSOPTIONS to 1.
Michael Su
SQA Engineer
Dear Michael su,
Thank you for your solution. It is working fine.
OSOPTIONS=>0 to enable snap inside hatch.
Suresh
