AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
how to enable grip inside hatch
4 REPLIES 4
suresh_070379
2737 Views, 4 Replies
I am trying to move the hatch by pick the end point of hatch line. But, it is not working without explotion. Is there any command to enable grib or object snap inside hatch. Kindly let me know.
Suresh
4 REPLIES 4
in reply to: suresh_070379
Click on "powersnapoptions" (or type _ampowersnap) and go to filter options - switch on what you want and press Ok.
i tried with ampowersnap=>filter options=>deselect hatch 1 & 2. But, after that also it cannot able to select the end point inside the hatch. Kindly let me know what mistake i did or provide any other solution.
Suresh
michaelsu
Please also set OSNAPHATCH and OSOPTIONS to 1.
Michael Su
SQA Engineer
Thanks.
Michael Su
SQA Engineer
Please mark any response as "Accept as Solution" if it answers your question.
suresh_070379
in reply to: michaelsu
Dear Michael su,
Thank you for your solution. It is working fine.
OSOPTIONS=>0 to enable snap inside hatch.
Suresh
”Boost
