I already have my Ribbons Tab with Panels already setup. And in those panels, I already have my dimension commands set up such as _aidimtextmove.
The Power Dimensioning Tab - out of the box - does not have _aidimtextmove anywhere in its panels.
So when I select a dimension, the annoying Power Dimension Tab pops up and disables all other tabs that you may have created. This is annoying.
You see, to move dimension text with leader (which is: _aidimtextmove with an auto setting of 1), I am not able to select the command because it is no where found in this Power Dimensioning Panel. I have it in my own dimensioning panel I created, but I can’t select it.
So to get rid of the "Power Dimensioning Tab" pop-up after just selection any dimension, read the attached document. It's simple when you go into CUI to make this change.
In the CUI, under Ribbon > Contextual Tab States > Dimension Selected , Remove “Power Dimension Single Selection”.
Yes I suppose I could customize my Power Dimensioning Tab to include more dimensioning commands. It's a matter of preference.
