AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
how can i shut off ampoweredit to use custom editor
3 REPLIES 3
andrew.nao
816 Views, 3 Replies
i have a custom text/attribute editor when i load it, it wants to use ampoweredit how can i stop using ampoweredit?
3 REPLIES 3
andrew.nao
in reply to: andrew.nao
im trying to edit a block with attributes, with a custom double click command its bringing up ampoweredit in the command line then does nothing.
Bob_Zurunkle
If you fire up NillaCAD (not simply change profiles) it wouldn't have the AMPower stuff...
If by some odd chance my nattering was useful -- that's great, glad to help. But if it actually solved your issue, then please mark my solution as accepted 🙂
andrew.nao
in reply to: Bob_Zurunkle
when i do that i get an error "cant load mcadapi.arx" even after a reinstall i still get this
”Boost
