Well i found out that one of my previous problems is also caused by this
problem... When this sudden change occurs (i refer to it as sudden, because
i can't place when it happens), the visibility enhancements don't work
anymore (http://discussion.autodesk.com/thread.jspa?threadID=369386) The
color of the visibility enhancement is then changed to: BYBLOCK. Another
thing i found: the symbols such as leaders, surface texture etc, also get
changed into a block reference.
I've been trying to work with 2004 version only but still it happend, so i
wish i knew how to show u how.
"nilanjan" schreef in bericht
news:21681322.1102491631307.JavaMail.jive@jiveforum1.autodesk.com...
> This can get a bit tricky. Is it possible that you did a Ctrl-S
unknowingly. If you did, the holechart would get saved as a block and
saveas after that would not change it back.
> Automatic save won't do this. I also don't think the other operations
would do this.
> Unfortunately, looking at the file won't help. I would need some steps to
reproduce the problem.
> -Nilanjan (Autodesk)
