AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Hide situation and constraint geometry
1 REPLY 1
Mike686
474 Views, 1 Reply
hi everyone, i have a problem with the hide situation
i have a drawing witch containt constraint geometry and block..
when i try to do a hide situation, when i select one of the constraint geometry it always said
"1 found
1 was filtered out"
so i can't select anything for the hide situation
is there limitation to the hide situation for constraint geometry??
Product Design Suite 2017
1 REPLY 1
michaelsu
in reply to: Mike686
Yes, this is a limitation. Hide situation will filter out constraint geometry. You need to remove constraint from the geometry first and then you can select it. I'll log a wish item in our system to track this issue.
Thanks.
Michael Su
SQA Engineer
Please mark any response as "Accept as Solution" if it answers your question.
”Boost
