AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Hidden line and power dimension
4 REPLIES 4
galbori
442 Views, 4 Replies
Why I can't use PowerDimension with hidden line?
4 REPLIES 4
michaelsu
in reply to: galbori
Can you be more specific about the issue? What kind of hidden lines are you using? Any steps?
Thanks.
Michael Su
SQA Engineer
Please mark any response as "Accept as Solution" if it answers your question.
galbori
in reply to: michaelsu
Thanks for your reply,
I've Autocad Mechanical 2010
When i try to use power dimension (AMAUTODIM not AMPOWERDIM) with line of layer AM_3 It doesn't work.I've the message "impossible to build dimension".it's not important how lines are selected, one by one or throught a window
michaelsu
Maybe you can find some info in this thread.
http://forums.autodesk.com/t5/AutoCAD-Mechanical/amutodim-not-creating-dimension/m-p/3533808/highlig...
Thanks.
Michael Su
SQA Engineer
galbori
Ok, tank. Now it's more clear Cordiali saluti Gianni Albori - CED
”Boost
