How can I edit weld symbols in Autocad that have been created with Autodesk Mechanical?
Solved by crashcontractor01. Go to Solution.
You should avoid editing Mechanical drawings in vanilla AutoCAD, you can corrupt the drawing.
This is not in all cases but it has happened and you need to be aware of it.
Jon
I would suggest, using their setup as a base for creating your own. Then you can add ATTDEF to it, also line lengths (%%U-%%U) among other things. Also, you can check exterior sites that support autocad for decent blocks you can insert, edit then save as you need it.
At this point it sounds like my best bet is to use a dynamic block with attributes. Thank you guys for the help!
To assist you in this problem we have come to this conclusion. Once we are completed an AutoCAD Mechanical drawing, we must save it off as a 2008 file. Any item created in AutoCAD Mechanical will be made into a block when it has been saved off the generic AutoCAD. We use the BEDIT command to make any changes needed in the generic file.
Hope that answers your question.
PS: We have never had an essue of a corrupted drawing in this process for over three years.
Ken Wood
Senior Designer, CAD Coordinator
ITT Exelis
