AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Hatch Transparency value not saved
1 REPLY 1
nstalker
436 Views, 1 Reply
I set my hatch transparencies to 75%.  I saved and closed the drawing.  When I reopened the drawing the transparency values were all at 0.
1 REPLY 1
Do you see this problem while setting the value for any drawing. If so, can you try resetting your AutoCAD profile as per the steps below,
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14823324&linkID=9240617
Also try to enable hardware acceleration and see whether it helps.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=5554010&linkID=9240617
If not, What type of hatches are using in your drawing ? Can you able to send one to us to investigate further.
Vinod Balasubramanian
AutoCAD Industry Support & Escalation Lead
”Boost
