It seems like since I downloaded Autodesk Factory Design Suite 2014, AutoCAD Mechanical 2013 has stopped working. It won't start up. It gets hung up on the splash screen every time. It gets to "Loading plug-ins... AcConnectWebServices.arx" and gets stuck.
I have a similar problem. Factory Design Suite 2013. AutoCAD Architecture in showing this message. AutoCAD is working normally. After reboot everything is ok for few hours. Something is blocking ACAD Arch, what can it be? Opened Inventor?
The problem is that you cannot disable A360 and its services inside Autocad options.If you have a computer with strong internet security (or without internet at all), the loading of the plugin takes a long time.
I found this solution: I tried it on Mechanical 2017, and while not fancy, it works.
- Go into c:\program files\Autocad 2017\ directory
- Look for AcConnectWebservices.arx file
- Rename it (ie AcConnectWebservices.arx$$$ )
- Lauch Autocad again: it will not find the file, so it will skip its loading, and increase the speed of the whole Autocad launching process
Of course you won't have any A360 related services, but if you don't use them, it's a nice solution to avoid the annoying hang at the startup.
Davide
PS: if you experience any problems deriving from this hack, of course you just have to rename the file with its original name
Was this working properly up to this point?
Mark Lancaster
& Autodesk Services MarketPlace Provider
Yes it was. I just tried to rename the file as suggested by another user, but that didn’t work either.
It also may be that I am using the term "hang-up" incorrectly. AutoCAD doesn't really "hang-up" ... it just quits loading.
