AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Folders and files cannot be saved when Autodesk 360 is not running.
2 REPLIES 2
nstalker
1306 Views, 2 Replies
If I don't have Autodesk 360 running in the background I receive this message when I save a file:
"Folders and files cannot be saved when Autodesk 360 is not running.  Start Autodesk 360 and try again."
This actually isn't true because it does save the file.  Also, I receive the message twice.  I don't want to run Autodesk 360 right now.  Is there a way to disable this notification window?
2 REPLIES 2
zalant
in reply to: nstalker
If you do not wish to use Autodesk 360, disable the service. You can do this as follows:
  1. Right-Mouse click the Autodesk 360 Sync applet found in the Windows Task bar Icon tray.
  2. Select Preferences
  3. Uncheck "Start Autodesk 360 when I log on to Windows"
  4. Select "Never Copy"
  5. Select "Save"
  6. Return to the Preferences dialog and select "Sign Out"
  7. Launch AutoCAD
  8. Type OPTIONS at the Command prompt
  9. In the Options dialog, select the "ONLINE" tab
  10. Uncheck "Enable automatic sync"
  11. Select "Apply"
  12. Select "Close"
Please post back here how this goes for you.
Zac Travis
Folder and files canbot be saved when Autodesk 360 is not running,Start Autodesk 360 try again
”Boost
