I was recently upgraded to AutoCAD 2014 and I cannot stand how the FILLET command now operates. Is there a way to make the fillet command operate like it has in every prior version of AutoCAD with which I've worked? I find having to set the redius through a Setup dialog box to be very annoying and not very user-friendly.
I've had this problem before, when I received an upgrade in AutoCAD Mechanical in the past, so I knew there was a simple way to fix this issue. What I did was modify the acad.pgp file so that when I type "F" for the fillet command, AutoCAD Mechanical invoked the fillet command, not the AMFILLET2D command that AutoCAD Mechanical points to as a default for the "F" keyboard shortcut. Open the acad.pgp file and scroll down to the bottom where the "User Defined Command Aliases" are located and make the change in this section.
