AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
FDS 2013 Premium Assets browser
3 REPLIES 3
boojie_recto
556 Views, 3 Replies
Can someone assist me with my problem? I'm using FDS 2013 premium. One reason I was excited about the product was the cloud-based assets available for download directly from the FDS UI. Unfortunately, I am not able to access these assets. Inventor just tells me that "Cloud assets are not available; you can use previously downloaded assests."
I tried hitting the refresh buttom several times but i get the same result.
I'm wondering what might be causing this problem? Is it my connection or there is really something on Autodesk's cloud servers where these assets are located?
thanks for helping out.
3 REPLIES 3
XuesongBai
in reply to: boojie_recto
Hi there,
I guess that Jeff has talked with you about the issue.
Perhaps you will be geting quick response about FDS issues if you post FDS questions directly to Factory forum.
http://forums.autodesk.com/t5/Autodesk-Factory-Design-Suite/bd-p/510
-Xuesong
Please mark as a solution if somehow I got it right.
boojie_recto
in reply to: XuesongBai
Hi Xuesong,
thanks for the advice. Anyway, would you happen to know where's Jeff? He hasn't replied to me. I thought we were going screensharing?
XuesongBai
”Boost
